STDV3.0 - WatchWindow - Expanding the display
pjacob
Posted on June 08, 2004 at 17:48
pjacob
Posted on June 07, 2004 at 20:14
Using STDV3.0, I want to see an array that is 32 bytes long.
In the 'WatchWindow' when I click on the '+' sign in order to 'Expanding the display' (as described in the user manual), I can only see the first 10 elements of the array.
If I want to see more, I have to go to the 'memory window' and scan through it in order to see all the data.
My question is:
Is there a way to expand an array (bigger than 10 elements) up to its end in the 'WatchWindow'?
sjo
Posted on June 08, 2004 at 09:18
Same process as older 2.54 - goto Tools/Options/Edit Debug modify Watch array expand ** items to suit.
sjo
pjacob
Works just marvellously.
Thanx sjo.
