ST7 RAM
adronico
Posted on October 30, 2003 at 22:34
ST7 RAM
adronico
Posted on October 22, 2003 at 12:49
Is it possible with the ST72F324 device to execute code in RAM between 100hex and 130hex assuming the Stack is empty i.e. pointing at 1FFhex.
sjo
Posted on October 23, 2003 at 06:44
If you keep an check on your stack usage this is ok.
Be careful if you are doing IAP as the stack (124 bytes) is required by the embedded commands.
sjo
developsofter
Check the Application note i have attached.
Hope it can help.
________________
Attachments :
ram_execut.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I09e&d=%2Fa%2F0X0000000bUS%2FU4wVgJeopsB8gFtySKTCjxxJlRd2dhUg3ns9QsJp51Y&asPdf=false
