ST7 assembler delay 3 sec
chill_just_chill
Posted on May 13, 2003 at 08:19
chill_just_chill
Posted on May 02, 2003 at 13:15
how can I create a delay of 3 seconds?
tia
Christophe
sjo
Posted on May 08, 2003 at 16:43
Best method is to use the timer in output compare mode, if you download the ST7 library there is an example of an RTC with the timer.
Hope this helps
SJO
itsmejatinus
Another way is to call function like-
void delay(void)
unsigned int a,b,c;
for (a=0xffff;a>=0;a--)
for ( b=0xffff;b>=0;b--)
for (c=0xffff;c>=0;c--);
You can set the value of a,b,c or add another variable to according to delay time & cpu clock frequency.
[ This message was edited by: Ranjeet on 13-05-2003 12:12 ]
