How to use binary numbers unstead of hex
us2
Posted on May 12, 2003 at 08:28
6 REPLIES 6
us2
Posted on May 08, 2003 at 09:53
Hi
How can I (if it is possible) do the following in C with a binary number instead of a hex number?
Code:
unsigned char x;
x= 01010101b; // binary number
/Ulrich
sjo
Posted on May 08, 2003 at 10:39
In Cosmic and metrowerks you would use:
unsigned char data;
data = 0b00000000;
SJO
us2
Posted on May 08, 2003 at 11:19
Yes but it does not work. I get an error when compiling: C2704 - Illegal number
/Ulrich
sjo
Posted on May 08, 2003 at 16:38
I have tested it in both cosmic and metrowerks with no problems ?
What compiler/version are you using?
You are using 0b00000000 not 00000000b as per your example ?
SJO
us2
Posted on May 12, 2003 at 06:33
Hi again
I am using Metrowerks Codewarrior ver. 4.1 build 0621.
I tried the method you suggested but still the same error.
Ulrich
sjo
I have checked my version and it is 4.2.5.766
Looks like you need to upgrade.
SJO
