reset the timers
adi2
Posted on November 24, 2003 at 13:51
reset the timers
5 REPLIES 5
adi2
Posted on November 24, 2003 at 12:01
hi !
when i use the output compare function , when i'm writing to the CLR register will it reset the counter ????
thanks.
adi
jatin
Posted on November 24, 2003 at 12:08
Which device are you using??
adi2
Posted on November 24, 2003 at 12:17
st72264
jatin
Posted on November 24, 2003 at 12:56
Yes, while using 16-bit timer/output compare function , the counter is reset by writing into the count low register(CLR). It is also mentioned into the datasheet.
adi2
yes ,it is written in the datasheet but not under the output compare function section and i just wanted to be sure.
thanks.
