2008-12-24 2:20 AM
2011-05-17 12:56 AM
Now there is a strange event.
I use STR911FAM44X6, I let bank 1(32k) be bootloader, bank 0(512k) be main program. I found when program running in main program, and I let RESET_INn pin short to ground for a while, the IC can't be RESET normally. But when I run in bootloader the reset is OK. Do somebody know why and please kindly advices me! Thank you very much,2011-05-17 12:56 AM
Please could you mention the silicon Revision, you are using? If it's a Rev G device or lower, hence it's a known issue already reported in the current Errata sheet (see section2.3) Kind regards, Eris.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
