2025-12-12 6:59 AM
Dear
Like my subject says, I am looking for a replacement part for M48Z128-85PM1 as this is now obsolete.
Thank you for helping me.
kind regards
Sanders
2025-12-12 7:56 AM - edited 2025-12-12 7:58 AM
As said by @Peter BENSCH there is no replacement for that device but look at these links if you have a battery issue:
May be you need to try that workaround.
Look at the images here.
2025-12-12 7:46 AM
Welcome @SandersF, to the community!
The device in question was a battery-buffered SRAM with a voltage of 5V, which has been obsoleted and uncommon for decades. I'm afraid you won't be able to find a replacement anywhere, and only a manually manufactured drop-in will help.
Sorry not being able to help you in this case.
/Peter
2025-12-13 3:37 AM
Thank you for your replies. I have ordered the small plate and will try to fix it like that.
Fingers crossed.
kind regards
