RAM again
denis_sandrine
Posted on July 03, 2004 at 08:48
RAM again
denis_sandrine
Posted on July 08, 2003 at 05:06
Hi!
I have some questions!!!!!!!!!!!!!!!!!
Can you give some references of RAM compatible with the ST10F168?(16 bit demultiplexed)
Can you tell me more about the BHE signal?
I know that it is slower using external RAM than internal memory : do you know how much?
Thank you
guenther
Posted on August 07, 2003 at 15:11
Quote:
On 2003-07-08 08:36, sandrine82 wrote:
Hi!
Thank you
Take a look at the SAMSUNG K6R4016C1D-TI10 256kx16SRAM.
I use it with an ST10F269 @40MHz 16 bit demux Bus without any waitstates.
Works great up to now. Should work with your F168 too.
wjohnson
Posted on July 02, 2004 at 13:21
How did you connect this RAM to the micro? We're hoping to connect like this (using an ST10F276 micro, basically the same as the 269)...
/WR -> /WE
/RD -> /OE
/BHE -> /UB
A0 -> /LB
We'd use a 16 bit demultiplexed bus. Would this allow us to write and read bytes and 16 bit words??
