PWM4 problem
jgil
Posted on September 04, 2003 at 05:23
PWM4 problem
jgil
Posted on May 17, 2011 at 11:55
Hello.
I am using uPSD 3200.
I'm trying to use the channel PWM4, but frequency calculations don't match.
I write:
PWMVP (0xAA) = 0x02 // Variable PWM Period Reg
PWMVPW (0xAB) = 0x01; // Variable PWM Pulse Width
sfr PSCL1L (0xB3) = 0x00; // Variable PWM Prescaler low
sfr PSCL1H (0xB4) = 0x00; // Variable PWM Prescaler high
The fosc=16Mhz.
But the output frecuency is 121Hz when i think that fout=4Mhz.
Why?
More. i write
PWMVP (0xAA) = 0x64; // Variable PWM Period Reg
PWMVPW (0xAB) = 0x32; // Variable PWM Pulse Width
And changing PWMVPW the pulse width don´t change.
Thank you very much
chris_baragnon
hello
I was using the PWM4 one time to generate a clock of 9 MHZ but after I stoped to use it.
maybe the attached file can help you.
totof.
[ This message was edited by: totof on 30-08-2003 00:20 ]
jgil
Hello.
Thank you for your answer. I test it at the DK3200 and working ok. But it doesn´t work on a microcontroller what i buyed. I tested the oscillator.
Thank you .
