PSDSoft Express Simulation Problem (registered input pin)
eparth
Posted on April 29, 2005 at 11:58
eparth
Posted on May 17, 2011 at 12:06
I design for a uPSD34xx. An input pin is declared as registered.
myInput PIN 42 istype ''reg''
then
myInput.LD = clkin;
Q0 := myInput;
Now when I simulate using testvectors the simulator always uses
the datavalue at the phsical pin, and not the data available at the clkin edge.
Ist this a limitation/bug of the simulator ? Or myInput needs a dot qualifier in the last equation ?
