Programm I-Flash with IEN=1
jduranhernandez9
Posted on June 28, 2012 at 13:41
I have been trying to programm the I-Flash while I am still working with interrupts. I can jump into the X-Flash and receive the data to programm. but when I start the programming process an error occurs, because an Interrupt comes and tries to read from the I-Flash (Interrupt array is in the I-Flash)
How can I programm the I-Flash while still working with interrupts?
I have tried using the SUSP bit from the Programming Flash resgisters. But it does not work.
Thank you very much for all the help you can give to me!
#programm-iflash #programm-st10
0 REPLIES 0
