Number of clock cycles
marvin78
Posted on November 26, 2004 at 04:30
5 REPLIES 5
marvin78
Posted on November 25, 2004 at 09:39
I need a list of the instructions with the number of cylces needed to compute that instruction. I couln't find that on the web.
We use: st72321
Where can I get this list?
Bastian
sjo
Posted on November 25, 2004 at 10:29
In Visual Debug/Develop goto Help/Help On Instruction menu item.
Each instruction is given a number of cycles required.
This information is also calculated in the simulator, View/ST7 Register have a look at the Time and Instruction counter tabs.
sjo
jatin
Posted on November 25, 2004 at 11:01
Pls download ''ST7 Family Programming Manual'' from the same site.
It explains all instructions and addressing modes etc.
wolfgang2399
Posted on November 25, 2004 at 11:14
Hi Bastian,
you can take the PDF-file of the
http://mcu.st.com/files/mcu/4020.pdf
There you find a complete description of each ST7 instruction beginning on page 33, including the number of cycles -cy-.
WoRo
marvin78
Thanks for that! Now I found what I was searching for.
Bastian
