2025-10-30 8:44 AM
Hello, our company is concerned about potential export control restrictions affecting Nexperia products.
We currently use several automotive logic devices from Nexperia and would like to know if STMicroelectronics offers equivalent parts as alternatives. Could you please advise?
Thanks,
Claude.
2025-10-30 8:52 AM
Hello, thank you for reaching out. STMicroelectronics has a comprehensive portfolio of logic devices that can serve as suitable replacements for Nexperia parts. You can reach them through this link: https://www.st.com/en/automotive-logic-ics.html.
I’ve attached here an x-ref PDF document listing all the ST Automotive Logic ICs Nexperia equivalent devices, for your reference.
Below you will find a preview of this dedicated Cross Reference with the Nexperia pin-to-pin replacements and suggested ST parts.
Nexperia Part Number | ST Suggested | P2P | ST Description | ST package |
74AHC14D | 74VHC14YMTR | yes | Hex Schmitt Inverter | SO 14 |
74AHC14D-Q100 | 74VHC14YMTR | yes | Hex Schmitt Inverter | SO 14 |
74AHC14PW | 74VHC14YTTR | yes | Hex Schmitt Inverter | TSSOP 14 |
74AHC14PW-Q100 | 74VHC14YTTR | yes | Hex Schmitt Inverter | TSSOP 14 |
74HC04BQ | M74HC04YTTR | no | Hex Inverter | TSSOP 14 |
74HC04BQ-Q100 | M74HC04YTTR | no | Hex Inverter | TSSOP 14 |
74HC04BZ | M74HC04YTTR | no | Hex Inverter | TSSOP 14 |
74HC04D | M74HC04YTTR | yes | Hex Inverter | TSSOP 14 |
74HC04D-Q100 | M74HC04YTTR | yes | Hex Inverter | TSSOP 14 |
74HC04PW | M74HC04YTTR | yes | Hex Inverter | TSSOP 14 |
74HC04PW-Q100 | M74HC04YTTR | yes | Hex Inverter | TSSOP 14 |
I hope this helps address your concerns and supports your sourcing needs.
Please let me know if you need further assistance.
2025-10-30 8:52 AM
