MTIM and MPRSR confused me
rk_web04
Posted on February 01, 2006 at 04:20
rk_web04
Posted on January 31, 2006 at 11:32
Hi.
I have a little problem in understanding. I try to drive a BLDC motor with the ST7FMC. But the working flow of MTIM timer is a little confusing.
For example:
F_Periph = 4 MHz and the MPRSR Reg is loaded by 8 and the uC works in switched mode.
So, that means the MTIM works at a clock of 7,8125kHz. Now it takes 19.2ms for next C event then MCOMP comprised 150.
Is this right?
Now comes the confusing part for me. What means the associated step frequenzy in table 40/page 175 at the datasheet? Is this the real clock for MTIM or what does that mean? :-?
Unfortunatly the describtion in the datasheet is not clear enough for me. Thats why I ask for some additional informations.
Thanks a lot,
RoB.
luter
Hi.
I would recommend u to post your messages on motor control forum.
There u can find answers on most of your questions.
About you current problem take a look on
http://mcu.st.com/mcu/modules.php?mop=modload&name=Splatt_Forums&file=viewtopic&topic=2696&forum=13
Good luck.
