Mar 3, 2025 12:55 PM UTC
LwM2M (Light Weight Machine to Machine) architecture vs Web socket + HTTP architecture
Hello everyone,
I am aiming to build a desktop application for configuring and monitoring IoT devices (e.g., routers, switches, ciphers, sensors, etc.). To achieve this, I am considering two architectural approaches:
  1. First Architecture:
    • The desktop application acts as a centralized LwM2M server (using Eclipse Leshan) to manage and configure IoT devices.
    • The IoT devices run Zephyr OS and act as LwM2M clients.
  2. Second Architecture:
    • A backend-frontend architecture where:
      • Backend-Frontend Communication: Uses WebSocket for real-time updates.
      • Backend-Device Communication: Uses HTTP for scalability.
    • The biggest advantage is that the backend can handle many requests from IoT devices without failing, ensuring scalability.
I believe the second architecture is simpler and faster to implement compared to the first one. However, I need advice on the following:
  • How to use the registry in LwM2M and how to map it to a database for simplified management.
  • General advice on choosing the right architecture and simplifying the implementation.
1 reply
Andrew Neil
Mar 3, 2025 1:19 PM UTC
