Lower inductor for SPV1040
Heaton.John
Posted on April 25, 2018 at 16:56
I am using the simulator for converting solar cells into 5V output to a USB plug. The simulator calculates a 648uH inductor which is VERY large, expensive and hard to find. How can I use a more standard inductor, like the 10uH stated in the datasheet for this design?
#spv1040 #solar
Patrizia BELLITTO
Posted on April 27, 2018 at 08:49
eDesignSuite calculates the optimized components for your design, according to different criteria.
However, if you prefer to use another inductor, you can click on the inductor value and select another one from the list.
In this way the solution is redesigned around your choice.
Best regards,
Patrizia
Patrizia BELLITTO
Best regards,
Patrizia
