2008-01-10 3:50 AM
2007-12-13 11:02 PM
Dear All,
i am about to start working on CAN module of ST10F269. For development i am using Keil Compiler. The first program i need to try is to exchange ''hello'' between 2 CAN Module of single chip.Is it possible?If YES then HOW? The first program i need to try is to exchange ''hello'' between 2 CAN Module of two different chip. if someone is having sample program to acieve same then please forword me. Regards... Yogesh2008-01-10 3:50 AM
Hello Yogesh,
You will find enclosed some ST10F269 CAN routines. I hope this helps you. Best regards, Najoua. ________________ Attachments : CANST10F269.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0IX&d=%2Fa%2F0X0000000bYY%2Fy4S42u0aR4tKU.Ytbj_iSnKeD7sTjLKKwZJY40JZDRU&asPdf=false
