Issue with Keil uVision3 and GXF loading
clanuchnik
Posted on December 09, 2006 at 00:22
clanuchnik
Posted on November 29, 2006 at 14:26
I am using Keil uVision3 for simulating an STR750
I use the GPIO demo project provided by Keil for this device.
After a succesfull compiling and linking I try to start the debugger and I receive the following message box:
Error: Could not load file
'C:\Keil\ARM\RV30\Examples\ST\STR75xLib\GPIO\output\GPIO.AXF'
Debugger aborted !
________________
Attachments :
Keil_Error.JPG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtJT&d=%2Fa%2F0X0000000aLT%2Fg7GAW5lemsYPih6FhTRXrqNDSazYn1TGZoDd1DWNm20&asPdf=false
javida14
The afx file is generated with a successful compile/link. Take a look again at the compiler results. I only get this error if try to invoke the simulator with a compiler error.
