I2C EEPROM troubles
james3
Posted on June 14, 2004 at 05:44
I2C EEPROM troubles
james3
Posted on February 13, 2004 at 06:22
I'm trying to get the M24C64 I2C EEPROM working with the microcontroller but it won't acknolodge the device select eventhough it is definatly correct (checked with an oscilloscope)?
don't suppose anybody nows why it isn't acknologing it?
adriano2
Dear Friends
I have tried to use the application notes, in fact I have used the application note AP1624 (hssc) on my ST10F168 FS board, where I have set the clock to 20MHz, but it doesn't work correctly! The EEPROM installed on the board is the 24LC02.
insideout_squirrel have you news?
Thanks a lot
Genius 1974
