How can I read from Main-Flash while running from Boot-Flash
Options
2009-05-11 12:45 AM
Posted on May 11, 2009 at 09:45
Labels:
Legacy Products
1 REPLY 1
Options
2011-05-17 2:52 AM
Posted on May 17, 2011 at 11:52
I am trying to read the flash content of the Main-Flash during boot-up (IAP - boot code is located in Boot-Flash). Purpose of my question: I need to create some sort of check sum for the content of the Main-Flash. I managed to switch from Boot-Flash to Main-Flash and vice versa, erease of the Main-Flash is also working. If I write a byte to the Main-Flash using the Polling-Mechanism for verifying it seems that the writing was ok. But if I try to read a byte manualy I only read ''trash''. Any hint is welcome. Best regards Sebastian
