How can I get 1ms timer with ST7LITE1xB ?
btjung
Posted on September 26, 2006 at 00:23
btjung
I want a 1ms timer with ST7LITE19B.
Should I use the LITE timer or the 12-bit autoreload timer?
Which register should be set?
and what value is needed for each control register?
For example, to get 8MHZ fcpu, I set the OPTION BYTE as follows :
CLKSEL = 1 1
PLLx4x8 = 1
PLLOFF =0
PLL32OFF = 1
OSC = 0
