hang after the message 'Freeing unused kernel memory..'
wangmowei
Posted on September 03, 2005 at 06:55
wangmowei
I run a customized linux system on stpc atlas, the kernel is 2.4.20, the filesystem is from redhat9.0.
On bootstrapping, the system boots from Lilo perfectly well until it
comes to the section shown in the attached file. It sits there after
the message 'Freeing unused kernel memory: 136k freed' and requires a reboot to.. produce the message again.
Any hint will be helpful and appreciated! Thank you!
