Get start with ST7 Visual Developement
chueva2005
Posted on May 31, 2006 at 12:00
chueva2005
I'm tring to use STVD7(Visual Developement) instead of the previous STVD7(Visual Debug) these days.When I prush the RUN BUTTON after successfully BUILD and REBUILD,it always says as follows in the OUTPUT WINDOW.
Program received signal SIGTRAP, Trace/breakpoint trap.
0x8000 in __stext ()
The settings and options I have made are listed below.
DEBUG TOOL:inDART-STX
The third part C compiler:COSMIC C
MCU selection:ST7FMC2N6
Programs:BLDC_3PH_SR_2.0 with generated .h files by AK-ST7FMC Control Panel
I am looking forward to you help!!
thanks
