FLASH problem
amoreno
Posted on April 07, 2008 at 08:29
FLASH problem
amoreno
I have a problem and I am not being able to solve.
Trying to write and read parameters from the FLASH, it looks works fine if I DEBUG the software (with J-Link)
But if I run the software without JTag debugger, the program “hangs� just when I try to read from flash.
Do you know why?
Here the routine that I use:
#define VERSIONS 0x000C0000
EIC_IRQConfig(DISABLE);
FLASH_Init();
FLASH_WritePrConfig (FLASH_B1F0,DISABLE) ;
Versions=FLASH_WordRead(VERSIONS);
EIC_IRQConfig(ENABLE);
I’m using WORKBENCH 5 EVAL and J-Link
Thanks for your helps, I’m in a hurry.
Best regards.
ALFA.
