error with st10f269
Posted on July 19, 2005 at 11:47
error with st10f269
4 REPLIES 4
Posted on July 18, 2005 at 09:05
with the ST10F269 are there any known errors, when there is a multiplication
with 0 using floating-point variables?
Best regards
Patrick
najoua
Posted on July 18, 2005 at 09:15
What software tool are you using?
Posted on July 18, 2005 at 13:10
I'm using the TASKING tools for C166/ST10 v7.5 r6
Patrick
najoua
Multiplying by zero does not cause any error with the ST10F269.
Please take a look at the C Compiler manual, ''Floating point trapping'' and ''Handling Floating point traps in a C application'' sections. So probably something else is going wrong. Please take a look at the value of the trap code (register R1) to find out what caused the error (exception). To do so, set a breakpoint on label __FPTRAPLOOP.
[ This message was edited by: Najoua on 19-07-2005 15:18 ]
