error in ST7 software library version 2.1
luter
Posted on May 09, 2005 at 12:18
luter
Posted on May 02, 2005 at 06:48
if i undetstood correctly, max value of watchdog timer is 0x7fh
in the file Wdg_hr.h WDG_MAX_VALUE is given as 0x3F
jatin
Posted on May 09, 2005 at 11:40
It is correctly declared in the ST7 Lib. The value 0x3F describes the maximum value for bits[5:0]. The bits[7:6] are always set to one to avoid the immediate reset + enabling the software watchdog.
luter
you r right, thanx for answer
