2005-12-19 8:24 PM
2005-12-07 9:45 AM
Hi, I am using st7flite29 and ASM and I am getting phase inconsistency errors. I have read the manual but can not see how to locate where the error is occuring. There are about 25 errors but I suspect that once one error occurs then the rest will automatically follow. Any ideas?
Steve.2005-12-19 8:24 PM
Hard to help ! Can you attach some files ? You should be right a first error can cascade the other ones. Did you try to remove some parts of the code to find where the error is coming from. Best regards Laurent
