emergency_cosmic_interrupts
irmakci2
Posted on March 20, 2006 at 10:36
irmakci2
Posted on March 17, 2006 at 10:35
Hi.I have problem using cosmic interrupt I wrote code in interrupt
routine for lite timer.In this routine I called another function!
But when I called the other function,I saw an error such as address between 0x80 and 0x80 is out of range.
And after I deleted this function,I took again same error
How can I solve this problem
please help me
luca239955_st
the description is not detailed enough to give a meaningful answer; if you can't explain better than this, try at least to attach a project showing the problem...
Luca
