debugger startup error
ongth60
Posted on May 05, 2005 at 12:14
ongth60
Posted on May 04, 2005 at 08:31
I cant open my realview debugger v1.6.1. The startup warning states the following :
Cannot obtain license for RVD IDE Support (feature st_rvd_ide_D97137A7) with license version >=1.6:
Feature has expired
Feature: st_rvd_ide_D97137A7
Expired date: 30-mar-2006
License path: C:\Program files\ARM\Licenses\license.dat
FLEXIm Error: -10,32
For further information, refer to FLEXIm End User Manual,
available at ''www.macrovision.com''.
Specify the command line option '-cmd' to start RealView Debugger in non-graphical mode.
Pls advise.
ongth60
Posted on May 05, 2005 at 11:16
hi,
i've managed to solve the problem. It seems that I accidently adjusted the time clock of my taskbar to the date that exceeds the expiry date. When I adjusted it back to the real time, it wouldn't work. So, what I did was uninstall the whole IDE and install it back. It works fine now. Thanks anyway.
