Constant at certain location (0xefff) with C compiler?
markbng
Posted on May 16, 2003 at 06:25
markbng
Posted on May 14, 2003 at 08:41
I wrote firmware that is able to update the firmware of the device ($e000-$efff) by USB. I want to place a constant at the end of this memory to check whether the firmware has been programmed/updated successfully.
This is the constant value:
const Byte FlashableVersionNumber=0x01; //place at 0xefff?
How can I do this with the Cosmic compiler? I was/am new in C, so please clarify with some code. Thanks in advance
Kind regards,
Mark
sjo
Posted on May 14, 2003 at 15:03
Have alook at
http://www.stmcu.com/forums-cat-256-1.html
, this topic was discussed.
SJO
stephanie23
In both C compilers (Cosmic or Metrowerks), you can define a variable by precising the address where you want it to be (like in the mapfiles for the hardware registers for instance!):
const Byte FlashableVersionNumber @efff;
