Breakpoints
michaelneeser9
Posted on March 12, 2010 at 10:12
Breakpoints
Posted on May 17, 2011 at 10:00
>>I cannot set more than one breakpoint in flash. Is there any trick to set more than one breakpoint ? I use IAR Workbench V5.4 and IAR jLink.
There are usually two, though one is probably consumed so you can start at main(). Sounds like you need to buy a FlashBP license for the J-Link from Segger. You should pursue support for IAR products from your vendor.
-Clive
