Licensed under GNU GPL v2
For bug reports, read
srst_only srst_pulls_trst srst_gates_jtag srst_open_drain connect_deassert_srst
adapter speed: 1800 kHz
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : STLINK V2J47S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.237574
Info : clock speed 1800 kHz
Info : stlink_dap_op_connect(connect)
Info : SWD DPIDR 0x6ba02477
Info : [STM32MP135DAFx.ap1] Examination succeed
Info : [STM32MP135DAFx.axi] Examination succeed
Info : STM32MP135DAFx.cpu: hardware has 6 breakpoints, 4 watchpoints
Info : [STM32MP135DAFx.cpu] Examination succeed
Info : gdb port disabled
Info : starting gdb server for STM32MP135DAFx.cpu on 3333
Info : Listening on port 3333 for gdb connections
Info : accepting 'gdb' connection on tcp/3333
Info : STM32MP135DAFx.cpu: MPIDR level2 0, cluster 0, core 0, multi core, no SMT
target halted in ARM state due to debug-request, current mode: Supervisor
cpsr: 0x200001d3 pc: 0x00004da8
MMU: disabled, D-Cache: disabled, I-Cache: disabled
Info : New GDB Connection: 1, Target STM32MP135DAFx.cpu, state: halted
Error: timeout waiting for DSCR bit change
Error: Error waiting for InstrCompl=1
Error: Error waiting for cortex_a_exec_opcode
Error: Error waiting for dpm prepare
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (4021 ms). Workaround: increase "set remotetimeout" in GDB
Error: Fail reading CTRL/STAT register. Force reconnect
Error executing event examine-start on target STM32MP135DAFx.ap1:
embedded:startup.tcl:1353: Error:
in procedure 'ocd_process_reset'
in procedure 'ocd_process_reset_inner' called at file "embedded:startup.tcl", line 1353
Info : stlink_dap_op_connect(reconnect)
Warn : STM32MP135DAFx.cpu: ran after reset and before halt ...
target halted in Thumb state due to debug-request, current mode: Supervisor
cpsr: 0x200001f3 pc: 0x00002058
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (4036 ms). Workaround: increase "set remotetimeout" in GDB
Error: DSCR InstrCompl must be set before leaving debug!
Error: Error waiting for resume
