JBrin.1
Visitor II
March 5, 2021
vnd7e025 - input capacitance limits
  • March 5, 2021
  • 1 reply
  • 635 views
Very interested in your vnd7e025. Datasheet doesn't have load capacitance limits - but states its rated for "capacitive and inductive loads". Can you please provide details about maximum capacitance and/or inrush magnitude and duration allowable for safe non-damaging operation?
1 reply
Peter BENSCH
As you probably know, there may be a large current peak with large capacitive loads. The VND7E025AJ is able to easily handle that and to drive inductive and capacitive loads due to the internal protection features:
  • for capacitive loads: current and power limitation
  • for inductive loads: negative voltage clamp
Because of these protective functions, it is not necessary to specify maximum values for e.g. inrush current.
/Peter
