2020-11-09 6:19 AM
I have found informations about Unicleo-GUI, and I would like to test it. There are many informations on ST page, but I could not find any link to download it.
So where can I download it?
Thank you
2020-11-09 11:28 PM
2020-11-09 7:38 AM
Hi @ANauz.1 ,
the link for the download is currently under maintenance, and should be available from tomorrow.
For now, I attach to this reply the AlgoBuilderSuite, which contains Unico, Unicleo-GUI and AlgoBuilder in a unique solution.
-Eleon
2020-11-09 11:28 PM
2020-11-10 12:26 AM
Great! Thank you
2020-11-10 1:17 AM
Hi @ANauz.1 ,
if it solved your question, please select the answer as "Best Answer", so that it can be helpful for future customer.
Thank you
-Eleon
2023-09-21 7:30 AM - edited 2023-09-21 7:31 AM
Hi Eleon,
I need to implement a model called "Machine Learning core"(https://www.futureelectronics.com/ftm/connectivity/future-electronics-sensor-based-machine-learning/) on my the STM32WB board.
I created the STM32WB+X-NucleoIKS01A3 stack. I need to activate Unicleo-GUI. https://www.st.com/en/development-tools/unicleo-gui.html.I have debugged and run this Firmware (DataLog Terminal, I attach the screenshots). https://www.st.com/en/embedded-software/x-cube-mems1.html.On Unicleo-GUI I can't see the transmitted data.
Can you give me some suggestions? I attach some screenshot.
My e-mail is : luigi.bibbo@unifi.it
Thank you.
Best regards
Luigi Bibbo'
