What is the difference between ST ISM330ISN and the SOX range ?
Evelina CAMILLERI
Luca SEGHIZZI
The difference is that the DSOX has a machine learning core based only on decision tree, it is limited
but highly efficient and it is a plug & play solution.
An ISPU device can be customizable with whatever ML algorithm you want to implement using C codes or NEAI studio which will find by itself the best library for the anomaly detection
Luca SEGHIZZI
