2021-07-25 11:29 PM
We are Reading Accelerometer Raw Data from the sensor and plotting FFT on excel sheet
The Motor is running at 800Hz we are observing peak at 2KHz . Not sure why we are getting wrong FFT plot .
Can you help why I am getting wrong FFT Plot.
2021-07-26 12:31 AM
Put your accelerometer close to your PC speaker/phone and play some tones (VOLUME UP) with this https://www.szynalski.com/tone-generator/
Is the FFT matching the PC generated tone?
Thats how i debugg accelerometer and FFTs
2021-08-10 12:26 AM
Still the problem repeat .
I am using the tone generator at 440 Hz instead of 440Hz observing peak at 800Hz .
2021-08-14 6:10 AM
can you plz help me out on the below comment
2021-08-23 8:54 AM
what happens if you reproduce a 220Hz? you observe peak at 400hz?
