VL53L1X Long-distance Ranging sensor: I have planned to integrate this sensor into my board. How is the I/O supply of 1.8V (standard mode) generated internally from the AVDD supply? Will there be any issue when I provide 2.9V (or) 3.3V supply to AVDD?
MM.11
On my board, I have two supply options within the permissible range of this sensor (2.6~3.5V) i.e. 2.9V & 3.3V. Will there be any switching noise coupling to the power supply due to the ranging operation of the sensor? Are there any recommendations to mitigate noise coupling?
John E KVAM
I don't know how the power is generated - only that it is and there are no issues.
The sensor creates it's own voltages internally from what you give it.
I've not heard of any complaints about noise coupling.
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
John E KVAM
