VL53L0X Register Map
Vivek Sen
Posted on February 17, 2017 at 20:28
I've been trying to use the VL53L0X TOF sensor to get ranging data but I'm having trouble finding what all the registers do? I tried looking through the datasheet and API specs but nothing seemed to clearly tell me what each register is defined as. I'm coding this on a PIC24 and I don't want to use the turn-key solution provided because I don't want it to be reliant on WIN32. I'm just trying to simply set up the I2C so that it communicates with the sensor properly. If someone could tell me what registers I will need to properly get the ranging data? Or if there's a register map? Thanks.
Soren Karlsen
Posted on February 22, 2017 at 11:20
Hi, I am confused about this too and have the same problem, but I think the problem has also been described in this thread:
https://community.st.com/0D50X00009XkeHcSAJ
Especially answer no. 3 is good.
If its not what you are asking about please let me know.
Best Regards
Søren karlsen
sahan sykam
Posted on June 29, 2018 at 09:01
may help you, got from arduino website
register addresses from API vl53l0x_device.h (ordered as listed there)
enum
regAddr
SYSRANGE_START =
0x00
SYSTEM_THRESH_HIGH =
0x0C
SYSTEM_THRESH_LOW =
0x0E
SYSTEM_SEQUENCE_CONFIG =
0x01
SYSTEM_RANGE_CONFIG =
0x09
SYSTEM_INTERMEASUREMENT_PERIOD =
0x04
SYSTEM_INTERRUPT_CONFIG_GPIO =
0x0A
GPIO_HV_MUX_ACTIVE_HIGH =
0x84
SYSTEM_INTERRUPT_CLEAR =
0x0B
RESULT_INTERRUPT_STATUS =
0x13
RESULT_RANGE_STATUS =
0x14
RESULT_CORE_AMBIENT_WINDOW_EVENTS_RTN =
0xBC
RESULT_CORE_RANGING_TOTAL_EVENTS_RTN =
0xC0
RESULT_CORE_AMBIENT_WINDOW_EVENTS_REF =
0xD0
RESULT_CORE_RANGING_TOTAL_EVENTS_REF =
0xD4
RESULT_PEAK_SIGNAL_RATE_REF =
0xB6
ALGO_PART_TO_PART_RANGE_OFFSET_MM =
0x28
I2C_SLAVE_DEVICE_ADDRESS =
0x8A
MSRC_CONFIG_CONTROL =
0x60
PRE_RANGE_CONFIG_MIN_SNR =
0x27
PRE_RANGE_CONFIG_VALID_PHASE_LOW =
0x56
PRE_RANGE_CONFIG_VALID_PHASE_HIGH =
0x57
PRE_RANGE_MIN_COUNT_RATE_RTN_LIMIT =
0x64
FINAL_RANGE_CONFIG_MIN_SNR =
0x67
FINAL_RANGE_CONFIG_VALID_PHASE_LOW =
0x47
FINAL_RANGE_CONFIG_VALID_PHASE_HIGH =
0x48
FINAL_RANGE_CONFIG_MIN_COUNT_RATE_RTN_LIMIT =
0x44
PRE_RANGE_CONFIG_SIGMA_THRESH_HI =
0x61
PRE_RANGE_CONFIG_SIGMA_THRESH_LO =
0x62
PRE_RANGE_CONFIG_VCSEL_PERIOD =
0x50
PRE_RANGE_CONFIG_TIMEOUT_MACROP_HI =
0x51
PRE_RANGE_CONFIG_TIMEOUT_MACROP_LO =
0x52
SYSTEM_HISTOGRAM_BIN =
0x81
HISTOGRAM_CONFIG_INITIAL_PHASE_SELECT =
0x33
HISTOGRAM_CONFIG_READOUT_CTRL =
0x55
FINAL_RANGE_CONFIG_VCSEL_PERIOD =
0x70
FINAL_RANGE_CONFIG_TIMEOUT_MACROP_HI =
0x71
FINAL_RANGE_CONFIG_TIMEOUT_MACROP_LO =
0x72
CROSSTALK_COMPENSATION_PEAK_RATE_MCPS =
0x20
MSRC_CONFIG_TIMEOUT_MACROP =
0x46
SOFT_RESET_GO2_SOFT_RESET_N =
0xBF
IDENTIFICATION_MODEL_ID =
0xC0
IDENTIFICATION_REVISION_ID =
0xC2
OSC_CALIBRATE_VAL =
0xF8
GLOBAL_CONFIG_VCSEL_WIDTH =
0x32
GLOBAL_CONFIG_SPAD_ENABLES_REF_0 =
0xB0
GLOBAL_CONFIG_SPAD_ENABLES_REF_1 =
0xB1
GLOBAL_CONFIG_SPAD_ENABLES_REF_2 =
0xB2
GLOBAL_CONFIG_SPAD_ENABLES_REF_3 =
0xB3
GLOBAL_CONFIG_SPAD_ENABLES_REF_4 =
0xB4
GLOBAL_CONFIG_SPAD_ENABLES_REF_5 =
0xB5
GLOBAL_CONFIG_REF_EN_START_SELECT =
0xB6
DYNAMIC_SPAD_NUM_REQUESTED_REF_SPAD =
0x4E
DYNAMIC_SPAD_REF_EN_START_OFFSET =
0x4F
POWER_MANAGEMENT_GO1_POWER_FORCE =
0x80
VHV_CONFIG_PAD_SCL_SDA__EXTSUP_HV =
0x89
ALGO_PHASECAL_LIM =
0x30
ALGO_PHASECAL_CONFIG_TIMEOUT =
0x30
