2019-10-16 4:23 PM
Hi. Based on the temperature sensor i would also love to know what form of medium would be best for communicating the temperature to the microcontrollers, and their reasons. Thanks
2019-10-17 7:41 AM
Hi @NKenn , can you be more specific about your request? The communication between ST temperature sensor is, for ST sensors, always the I2C standard. Otherwise, if you need suggestion on the best mounting guidelines for optimizing the temperature sensor response and accuracy, an application note will be available soon. You can follow by now online guideline such as the one at this link. Regards
