ST tile box pro heading drift issue
DavidThomas
Hi all,
I am using ST tile box pro and logging IMU orientation data for my testI did place that module in a robotic arm and then calibrate the accel sensorI observed 20 degree drift in the  heading value  after the calibration .
Before calibration almost 0. I did ensure the origin. Kindly explain what's happening after the calibration. Thank you.
12 REPLIES 12
Miroslav BATEK
Hello @DavidThomas I'm sorry I'm on business trip I will come back to you next week.
Miroslav BATEK
Hello @DavidThomas,
Recommended sampling rate for MotionFX is 100Hz.
Atime represents weighting on Kalman filter’s measurement noise matrix, increasing this will reduce the trust on the accelerometer sensor measurements.
Atime = 100 was just an example, you can try different values to fine tune the algorithm for your use case.
Thank you so much @Miroslav BATEK .
