2022-06-27 12:24 AM - last edited on 2025-12-22 12:54 PM by Andrew Neil
I need to understand what is the right SMD footprint recommendation for LIS2DH12.
Recommendations in TN0018 SMD guideline AN , ultra librarian recommended land pattern and footprint actually used in DIL24 adapter significantly differ from each other.
Attaching Allegro footprint downloaded from ST site LIS2DH CAD models and DIL24 adapter gerbers. As it can be seen part's footprint significantly differs. Need to know which one should I follow in my PCB design
2022-07-27 8:51 AM
Hi @MFish.1 ,
sorry for the delay in our answer. I suggest you to use the STEVAL-MKI151V1 recommendation, since the steval is specific of the LIS2DH12 device and is proven to work on the field.
-Eleon
