2018-06-25 03:26 PM
I am trying to dynamically configure the interrupt threshold on the LIS2MDL. It seems that sometimes after setting a new threshold, the old threshold still is in effect and causes an interrupt transition on the output pin. Is there any minimum (settling) time required after setting a new threshold on the LIS2MDL?
Thank you.
2018-07-04 01:02 PM
Hi - Update to all. I have determined it was an issue with my code. The updated settings do seem to be taking hold correctly/immediately.
2018-06-25 05:46 PM
Do the settings and new measurements read-back properly?
2018-07-02 01:08 PM
Yes the new settings read back from the registers immediately
2018-07-04 01:02 PM
