Retrieve acceleration data with and without high pass filter - LIS2DW12
‎2024-03-19 6:53 AM
Greetings
Is it possible to run the LIS2DW12 accelerometer for a single sample with its high-pass filter disabled?
I am using the FIFO with the high-pass filter enabled for regular sampling on interrupt wake-up, but would like atleast a single sample on demand, with the high-pass filter disabled, after reading the FIFO data.
In my INT1 ISR, I have tried turning the filter off after reading all the samples from the FIFO, but no samples are returned.
Accelerometers
‎2024-03-19 8:41 AM
Hi @ZAIDS-S23 ,
I am not sure I understood the question: do you mean whether you can acquire a single sample while keeping the HPF disabled?
‎2024-03-19 8:47 AM
Yes, that is correct, but after originally enabling it and starting the sensor.
Currently, my logic to read samples from the sensor:
- Enable HPF in CTRL6 register, enable wake-up interrupt and fifo.
- Start the sensor by writing configuration to CTRL1 register.
When the sensor wakes up, samples and stores the samples in the Fifo, i read them out.
After reading them out, I want to obtain a single sample with the HPF disabled.
‎2024-03-19 8:52 AM
Ok, this procedure works. When you remove the filter the effect is instantaneous so I confirm that you can acquire the single sample.
