2025-04-30 12:52 AM
Hi all,
Could you please tell me if the temperature sensor of the LIS2DW12 is used to correct the acceleration sensor?
Thanks all,
2025-04-30 1:39 AM
Hi @meco ,
No, the temperature sensor is not used to correct the accelerometer outputs.
2025-04-30 1:04 AM
Ciao @meco ,
What do you want to correct for the accelerometer?
2025-04-30 1:31 AM
hi Federica
Can you please tell me whether the output of the built-in temperature sensor is automatically used to correct the output of the three axes (X, Y, Z)?
Thank you
2025-04-30 1:39 AM
Hi @meco ,
2025-04-30 4:07 PM
hi Federica
Problem solved Thank you
