Question from Predictive Maintenance Webinar 29th of April: How much data does log in cloud per hour from one sensor?
Pasi MYLLYMAKI
Vladimir  JANOUSEK
This can be programmed eventually of course. In the example for STWIN using the wifi expansion and cloud dashboard, you can currently set, if to get data every 10 to 60 seconds, this is done with easy to use sliders in the cloud"set streaming time" settings.
