2021-09-16 1:37 AM
I am using the eval board STEVAL-MKI210V1K, iNemo inertial module kit based on ISM330DHCX.
I am trying to have datas from the temperature sensor.
I am using the official driver of ISM330DHCX and i did my own program.
When i am reading datas, i check my SPI communication with an oscilloscope, my MOSI is good but i dont received anything by the sensor (MISO).
in MOSI, I have 1 byte for the register and 1 byte with 0.
in MISO, I have 1 byte of FF and 1 byte with 0.
All my pins are set with a pull up.
First of all, is it a problem with my hardware ? can you tell me the shematic pins of the STEVAL-MKI210V1K for a communication SPI.
I dont think that my program is wrong because i send the good thing in my MOSI pin.
Thank you for your help.
2021-09-28 1:39 AM
Hi @Idzfg.1 ,
you can find the pin out connections for your situation at page 34 of the datasheet
try to read the WHO_AM_I register first, so that you can be sure that it is not a hardware problem
Niccolò
