Motion processing feature on MEMS Hardware
2019-05-23 3:43 AM
@Eleon BORLINI
Greetings of the Day
Currently I am using LSM6DSM as my IMU. Now in this sensor I need to write my own function to obtain the quaternions and then based on that obtain the roll, pitch and yaw of the system. The question that I have is , does ST provide an IMU that already has on board motion processing that can calculate and return the quaternions ?
Thank you
- Labels:
INEMO-Inertial Modules
2019-05-24 12:58 AM
Hi @Altamash Abdul Rahim , ST provides a number of libraries that implement motion algorithms, called X-CUBE-MEMS1. The reference HW design is STM32+Sensor, but the concept could be extended to all platforms. I suggest you to start from the eCompass feature, that provides as output the device orientation in terms of quaternions and Euler angles (although referring mainly to LSM6DSO sensor). Regards
2019-05-24 12:58 AM
