LPS25HB reading
ruizhang83
Posted on October 13, 2016 at 15:47
Hi
I have 2 LPS25HB pressure sensors. I moved them from exact the same level to another level. The readings from both sensors are different. The start points are different and the slope of the value change is also different!
However, i just programmed to read the value out without editing any reference or offset, or differential setting.
Can i correct the results by editing some registers, if so which registors?
Rui
0 REPLIES 0
