2024-10-16 10:02 AM
I am trying to read data in continuous mode from the LIS2MDL on a personal board with the help of the exemple(https://github.com/STMicroelectronics/STMems_Standard_C_drivers/tree/master/lis2mdl_STdC/examples) and driver (https://github.com/STMicroelectronics/lis2mdl-pid/tree/56a8a1ddb1bd21d98151372b5fa4f48ffa9e1a39).
I am able to retrieve the ID of the chip and configure it in continous mod.
But the problem is that the data ready register always return 0x00.
2024-10-23 06:37 AM
I am using a board i made with an stm32h743vit6.
After some change with the code i was able to get some value by removing this line in the exemple.
/*lis2mdl_reset_set(&dev_ctx, PROPERTY_ENABLE);*/
2024-10-23 06:09 AM
Hi @spglou ,
What is your acquisition system? Are you using the STEVAL-MKI109V3?
2024-10-23 06:37 AM
