Is there a specification for change in zero rate level vs time?
osmaneralp
Posted on November 13, 2013 at 00:38
If I measure the zero rate level for a few seconds, I can get an average measurement and use it to cancel out drift. However, the zero rate level changes over time. I want to choose a gyro with the smallest drift. How is change in zero rate level specified in the data sheet? I can't find it.
Thanks,
Osman
Thiago REIS
Posted on November 18, 2013 at 15:34
Hello Osman,
What is the gyroscope that you are referencing?
For L3GD20, the attached datasheet contains on page 9, table 3 a section showing the zero-rate behavior depending on the FS.
Please let me know if this was the information that you were looking for.
Thank you,
Thiago Reis
________________
Attachments :
L3GD20.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzJ0&d=%2Fa%2F0X0000000bJk%2FfWdyM6cBTKVQIGMdWGWpsNRgS6SekzNB_Y.KsNAyK_s&asPdf=false
